Hi guys I’m planning the electrics for my 4m x 3m workshop. I’m struggling with how to get legit power to it. I currently have an extension lead going from a socket in the garage, up over the back wall, down through the soffit and through the top of the workshop wall. Its time to do it properly so I am installing a 3-way consumer unit, 4 LED battens, 6 LED downlights and several double sockets.
The workshop is positioned to the rear of a single garage with a gap of about 500mm between the two buildings. The garage is wired to the house consumer unit via armoured cable (6mm² I believe). The armoured cable is terminated at the front of the garage via an external junction box.
I’m thinking: run 6mm² T&E on inside of garage from the external junction box, taking the same route as the extension lead, over the back wall, through soffit and into the workshop but add a steel conduit between the buildings. Does that sound ok? Or does it need to be armoured cable in the conduit?
Many thanks
Chris
Many thanks
Chris
