I have built a small workshop lean to up against my existing garden wall in my garden adjacent to the garage (separated by a 1m wide path. The garage has an electric supply already but it needs upgrading as I believe it to be simply some twin and earth flat cable run from the house via a fused switch (about 10 - 15m).
My plan is to run a new supply using 4mm2 armoured cable from the house distribution board which has room for one more RCD. I will fit a 32 or more amp breaker in the consumer unit?
The 4mm2 armoured cable will then run along the side of the house, along the garden wall (The cream coloured wall on the right hand side of the pic above) to the workshop where it will slip under the facia board. It will then terminate in a small consumer unit which will provide power and light circuits to the workshop and power and light circuits for the garage. The garage power and light will then run under the cladding into some PVC piping into the ground, under the path and into the garage.
In the workshop I may have a 2.5 - 3HP compressor and possibly a Clarke 150 Amp Welder, the welder requires 15 amp min 230v single phase. Otherwise it will standard power tools. Workshop lighting will be a single strip light with additional mobile lighting over the work area. The garage will be converted to a computer / hobby electronics training / making area consisting of around 6 PCs a soldering station in total around 10 double sockets. The lighting in the garage will probably consist of 6 x remote controlled LEDs.
I have been seeking advice from my father in law who is now retired but has been an electrician for most of his life.
Questions:
1. For garages and garden workshops does the work need to conform to Part P of the electrical regulations?
2. Can I do it myself and not have it tested or do it myself and have it tested and certified?
3. Does my plan make sense?
4. For the garage I have been advised that I could run a single supply into the garage from the mini consumer unit in workshop terminating into a fused spur and from there split the sockets and lighting circuits.
Questions:
