Bit of advice for workshop power.
Discussion in 'Electrics UK' started by onionsa, 21 Apr 2020.
  1. onionsa
    onionsa
    28 Oct 2017
    176
    Thanks Received:
    Country:
    I’ve got a workshop built on the back end of my garage. The garage has existing power to a single socket and spurred to an FCU for the light.
    I’d like to run multiple sockets and a new light in the workshop from the feed, but not sure how best to achieve it. Could someone advise?
  2. Sponsored Links
  3. terryplumb
    terryplumb
    8 May 2017
    6,351
    Thanks Received:
    1,334
    Country:
    Where does the supply to socket originate from ? Cable from house directly ,or is it from a fuse board in the garage ?
  4. onionsa
    onionsa
    28 Oct 2017
    176
    Thanks Received:
    Country:
    It comes from the main CU in the house. Has it’s own breaker.
  5. terryplumb
    terryplumb
    8 May 2017
    6,351
    Thanks Received:
    1,334
    Country:
    What type and rating is the breaker.
    For instance RCBO ,MCB , 16 amp ,32 amp ?
  6. chivers67
    chivers67
    18 Nov 2008
    1,456
    Thanks Received:
    178
    Surrey
    Country:
    Also how big is the Cable?
  7. onionsa
    onionsa
    28 Oct 2017
    176
    Thanks Received:
    Country:
    Just looking around a bit more and as this is from the CU it will be ok if done as a radial circuit?
  8. flameport
    flameport
    10 Mar 2007
    10,095
    Thanks Received:
    2,037
    Poole, Dorset
    Country:
    Why wouldn't it be?
    Almost all circuits are radials.
    As has already been asked:
    What size is the cable from the consumer unit to the garage
    What device(s) protected the cable in the consumer unit - add pictures here if unsure.
    What distance between consumer unit, garage and the workshop
    What is to be used in this workshop ?
  9. onionsa
    onionsa
    28 Oct 2017
    176
    Thanks Received:
    Country:
    This is what’s in the consumer unit. And I was thinking something like the attached.
    • Like Like x 1
  10. Sponsored Links
  11. onionsa
    onionsa
    28 Oct 2017
    176
    Thanks Received:
    Country:
    It’s 2.5mm2 T&E
  12. ldoodle
    ldoodle
    12 Apr 2010
    609
    Thanks Received:
    7
    Kent
    Country:
    I did this a few years ago. I had another (smaller) CU put in the shed, feeding sockets and lights from there.
  13. terryplumb
    terryplumb
    8 May 2017
    6,351
    Thanks Received:
    1,334
    Country:
    What were you contemplating plugging into the ten socket outlets ?
  14. onionsa
    onionsa
    28 Oct 2017
    176
    Thanks Received:
    Country:
    Sorry just seen the questions. Was on the phone app before and it wasn't updating the post.
    Just to clarify:
    What size is the cable from the consumer unit to the garage - 2.5mm2 T&E
    What device(s) protected the cable in the consumer unit - add pictures here if unsure. - Pic above, seems to be 20A breaker
    What distance between consumer unit, garage and the workshop - CU to garage ingress is about 1.5m max
    What is to be used in this workshop ? - Nothing major, 3d printer, CCTV, a few battery chargers. its more a hobby shop than industrial unit.
  15. terryplumb
    terryplumb
    8 May 2017
    6,351
    Thanks Received:
    1,334
    Country:
    Then the 20 amp circuit should be ample for your needs.
  16. onionsa
    onionsa
    28 Oct 2017
    176
    Thanks Received:
    Country:
    Cool, and my very rough diagram looks ok for connections?
  17. terryplumb
    terryplumb
    8 May 2017
    6,351
    Thanks Received:
    1,334
    Country:
    From what your pic of CU shows ,it would appear that the circuit has RCD protection , does it ? What size cable will you use 2.5 mm ? What testing will you do before energising the circuit after alterations ? Diagrams ok.
Loading...
Share This Page
