Bit of advice for workshop power.
28 Oct 2017
I’ve got a workshop built on the back end of my garage. The garage has existing power to a single socket and spurred to an FCU for the light.
I’d like to run multiple sockets and a new light in the workshop from the feed, but not sure how best to achieve it. Could someone advise?
Where does the supply to socket originate from ? Cable from house directly ,or is it from a fuse board in the garage ?
It comes from the main CU in the house. Has it’s own breaker.
What type and rating is the breaker.
For instance RCBO ,MCB , 16 amp ,32 amp ?
Just looking around a bit more and as this is from the CU it will be ok if done as a radial circuit?
Why wouldn't it be?
Almost all circuits are radials.
As has already been asked:
What size is the cable from the consumer unit to the garage
What device(s) protected the cable in the consumer unit - add pictures here if unsure.
What distance between consumer unit, garage and the workshop
What is to be used in this workshop ?
This is what’s in the consumer unit. And I was thinking something like the attached.
I did this a few years ago. I had another (smaller) CU put in the shed, feeding sockets and lights from there.
Sorry just seen the questions. Was on the phone app before and it wasn't updating the post.
Just to clarify:
What size is the cable from the consumer unit to the garage - 2.5mm2 T&E
What device(s) protected the cable in the consumer unit - add pictures here if unsure. - Pic above, seems to be 20A breaker
What distance between consumer unit, garage and the workshop - CU to garage ingress is about 1.5m max
What is to be used in this workshop ? - Nothing major, 3d printer, CCTV, a few battery chargers. its more a hobby shop than industrial unit.
From what your pic of CU shows ,it would appear that the circuit has RCD protection , does it ? What size cable will you use 2.5 mm ? What testing will you do before energising the circuit after alterations ? Diagrams ok.
