Worktop Mitre
24 Jun 2004
Staffordshire
I am in the process of fitting a new kitchen. My brother-in-law is helping, and provided useful tools such as a router and worktop mitre jig.
The problem I have is that he made the first mitre joint in the worktop but I'm not happy with it - there is a slight gap in the join, and the mating surfaces are not perfectly level. The join was sealed with silicon and a colour matching resin provided with the worktop, then pulled together with worktop clamps. Has anyone tried to split such a join? I thought of applying some solvent to the join to try and soften the resin.
If I can split the join without wrecking the worktops, I can clean up the mating faces, insert some biscuits to help keep the joining surfaces level along the length of the join and try again!
Also, is a router with biscuit cutting tool accurate enough for worktop biscuit joints or would you recommend hiring a biscuit jointer.
Any help or advice greatly appreciated.
A lot of worktops are slightly bowed in their width which makes fitting a bit of a b*gg*r at times - and nbetter done by two men than one.
Yes - the joint can be broken, but you run the risk of chipping the laminate when you break it so try to avoid pulling up at the ends, instead gently lift the joint and try to break it from beneath.
I don't see why it should be any less accurate.
The only thing I'd say is that this is at best a risky job and you've no guarantee of success.
Scrit
Thanks for the advice. I think I'll try and split the joint using acetone solvent to try and soften the colorfill, loosen the connecting bolts and push up from the bottom as you suggest.
I think I'll avoid using biscuits as it seems to me they could be a hinderence in aligning the join unless cut absolutely spot on.
I think I'll also just use silicon for the initial join and only use colorfill to fill any imperfections from the top after the join is made. The colorfill sets very quickly and seems like it might prevent the joint from pulling together tightly unless the join is tightened extremely quickly.
