Cutting and joining worktop
18 Feb 2006
Birmingham
Hi all
I have purchased 2 lengths of 2m worktop for my garage units and was wondering if I could use a worktop jig and router to trim the edges ready for doing a butt join, and the edges ready for edging strip
This will be my first ever attempt and have purchased a 900mm worktop jig, and thought the garage worktop would be a practice attempt.
Also should I use biscuits and what glue would be best for the join, would D4 glue be ok?
Thanks in advance
If you use counter top connector bolts, you don't need any glue, biscuits et'c. just silicone on the joint faces before drawing the connectors tight...pinenot :)
I will be using connector bolts, so just clear silicone will be fine?
Can I use router to make straight cuts?
You can cut from either side for straight cut. But then you don't need a jig for that.
Make sure you cut away from the bullnose edge and not toward it or it will shatter the laminate.
You could use biscuits as well as the bolts to align the tops when joining. This is what i do on a straight cut, but it isn't absolutely necessary.
Thanks.
Think I will cut it from the back to ensure I don't scratch the laminate, and go from the bullnose end to the back, using 3-4 runs, adjusting depth each go.
Will try without biscuits if it can be done as it will save me buying a biscuit joiner
Just got back and checked which router and bits I have. It's a cheap 1020w 3/8" (think it was from b&q), and trend 1/4" bits. Purchased in my early DIY days, although never used. Can't remmber why I got trend bits which cost me more then the router :P
Will this work, or do I need a 1/2" router?
EDIT
This is the one I have, just branded in the old branding
http://www.diy.com/nav/fix/power-to...ce-Power-Router-1020W-12389422?skuId=12910126
As you look at the worktops the left hand one will be routed the correct way up, from the front to back. The right hand worktop would be turned upside down and again routed from the front of the worktop to the back.
If you know anyone with a plunge saw and rail (festool ts55 or similar) they could do the cuts for you. These would be good enough to join together without routing. You'd then have to use a router to create the pockets for the worktop connectors though.
