- Joined
- 11 Nov 2004
- Messages
- 19
- Reaction score
- 0
- Country
Hi, currently doing up the spare room we have to become our daughter's bedroom. It currently is a darkroom. It has two external walls - longest N facing, shortest W facing and is the back room of a typical Victorian terraced house, so notorious for being cold.
Current loft space above boarded over and full of boxes! I probably will remove all boxes, remove boarding and add more insulation above. Currently cross braced with joists at right angles to originals to add strength to hold boxes. I can add an additional 75-100mm to existing.
I was thinking about hacking out all the original plaster and drylining with either insul-plasterboard or battens, batts, membrane and plasterboard to a depth of 50mm. Original plaster is old so at least 30-40mm thick. I'll lose minimal space this way in what is a smallish room. Will be both external walls so only one window frame to worry about. This will be replaced with a new double glazed unit as the 60's single glazed aluminium frame is ~@%&!
What are the pros and cons of both methods and more importantly - is it worth doing?
Nick
Nick
