Might seem a daft question, but the wall will be a semi-circle of blocks, radius 3.3m, @1m high, 10m around the circumference.
If I did it in dense concrete blocks on their sides it would be 10 courses high approx, 22 around the circumference so 220 blocks in total at about 20kg apiece- so a solid semicircular wall weighing close to 4.5T.
The ground it is to go on is excavated and is glacial till- no clay/vegetation whatsoever- well sorted and not liable to compress at all so if I dig down a bit(100mm?) and set the first course on a generous bed of concrete to get the radius set and all level to kick it off, when it's been built what would be the chance of it moving be? It won't fall over that's for sure, but don't want it cracking. I would put in weep holes and backfill with gravel but the ground is totally free draining anyway so probably don't even need that...
Any thoughts?
Any thoughts?
