My old house with plumbing difficult to decipher. My plumber took on a difficult job.
However I need your help to find where should be the Feed & Vent connected from Expansion cistern in my fully vented system boiler.
Replaced with new boiler,DHW tank,Expansion Cistern,and Cold water Tank and put in a "S" plan with two new honeywell two-way valves & new Grundfos pump.
initially the plumber got the pump with shaft vertical. After discussion here I got it changed.
The pump could not be set on level 2 or 3 as I gather it is pumping over and pulling [I heard my Plumber & Gas Installer discussing]. So the set it at 1.
I suspect it is still pulling from the expansion cistern because each morning on my boiler start with bubbling in the expansion cistern.
Also I find one radiator to my bathroom connected directly to HF pipe needs bleeding air daily.
Also when I touch the Feeder & Vent pipes from & to the expansion cistern warm to the top.
I suspect the feeder & vent from the expansion cistern may have to be realigned differently.
Can some one help me with drawing or correction on my photos? View media item 53964 View media item 53963 View media item 53966
