Would you use props here?
17 Jul 2017
I am planning to remove a gas flue box and brick up the opening (single brick wall downstairs, but a chimney on first floor and in loft). I plan to remove the box and the rough filled bricks around the box.
I was planning to put a prop either side with a needle at approximately where the cross is on the first picture (1 metre above the floor) , and then just brick up the hole.
The flue box is 350mm deep, so with props on 1 metre centres I should have enough room to maneuver the box out.
Would you use a prop in this situation?
Thanks. So you don't think that the gas flue box could be providing any meaningful amount of support, that would need to be compensated for?
looks like its just infill in the opening and the wall above self supporting.
