Wylex isolators
31 Mar 2006
Leeds
Any one been having issues with these 4 pole isolators?
I've had two of them on different sites fail with one of the phases open circuit within the last month. One of them was less than three years old. :roll:
Strange. Were the two that failed operated very often?
Did they fail after they had been manually opened (i.e. failed to re-close when 'told to'), or did they just spontaneously 'go open circuit' whilst they were closed (which would seem a very strange thing to happen)?
Kind Regards, John
I don't think either of them were ever normally touched. The one in the picture supplied a car ramp in a farmers workshop. It was rarely live as it was generator fed, and very lightly loaded.
How odd. I presume it showed no signs of having been traumatised?
Kind Regards, John
I have had 2 of these become faulty after installing them with a few months. One was exactly the same problem as you, where a phase was not isolating through the switch and gave a continuity reading through the switch in both on/off positions.
The other fault was if the switch was latched all the way to the on position it didnt work. If you pulled the switch down a couple of mm it turned on. Pretty strange fualt and deffinetley a manufacturing fault. Replaced both and havent had any problems since.
Both switches were in good physical condition. I stripped down the one in the picture and all the contacts looked clean and in good condition.
I've been installing these isolators all my career with no issue, but to me it's just another sign that wylex have lost the plot. I certainly won't be installing any more of there products.
Did your autopsy give you any answer as to how/why one of the poles got 'stuck' in the open state? Weak spring?
Kind Regards, John
That's the 921E isnt it Rob?
Never known one fail, but not sure of their work load.
Has it been used to switch heavy loads online?
No it was just supplying a hydraulic car ramp and would never have done on load switching. I've been using them for years but the two recent failures is a bit of a worry for me.
