wylex mcb/rcd board fault
15 Nov 2006
Fife
hi, ope someone can help in here.
i recently installed a wylex mcb/rcd board in my house which appears not to be testing properly. i only have 6 mcb's in the board so have the main switch wired into the rcd and a busbar from the rcd to the mcb's. one on the mcb's for a lighting circuit has been tripping occasionally but i'm not too concerned about that at the moment, the main problem i have is that the rcd does not trip when i press the test button, any suggestions?
Assuming you have power to the RCD, with both Phase and Neutral passing through it before going to the phase busbar and the neutral block, it's faulty.
But it's possible you've fitted it wrong.
If you can lay your hands on a digital camera and put up a pic of the inside of the CU (power off) we may spot something.
does this look like it is wired correctly?
looks all right. Should trip if the power is on and you press the test button.
it did when i first put it in but for some reason does not trip any more. i'll try replacing the rcd.
thanks
If the CU is wired as per your picture then I would say it sounds like a faulty RCD.
Sadly not that uncommon for wylex :cry:
Its all made by electrium, the same company that makes volex.
But also the same Co. who makes Crabtree, and most of the Wylex RCD's I've come across are the same as the Crabtree ones.
I'm a bit of a Wylex fan (don't tell anyone!) and fitted literally 100's. I've only ever had two failed RCD's, one straight out of the box, and the other after 5 years service.
hi johnd, hope you can help my adp 8520 dishwasher has stoped working the first 3 program lights constantly flash & it beeps 10 times can you help with this?
How does that relate to a suspect RCD?
Maybe you could start a new thread to get a response.?
