Hi All, new here so please bear with me.
I have had a new boiler installed Wooster Bouch which has been configured in a y plan formation.
I have Boss controler BUP2 and thermostat
I had a plumber fit the boiler and a electrician wire it up.
After the electrician had finished there was a problem with the switching boiler on and off. Wooster Bosch suspected a faulty board in the boiler and came out to swap. When they arrived they found the electrician had not wired it properly and gave me a contact number for electrician to discuss the problem directly with them.
Electrician came back and sorted the on / off problem but could not sort the pump run on.
I have also noticed the electric valve is warm to touch when the system is not running, but I am not sure this is normal can anyone confirm?
when the HW is on I can feel hot pipes before the pump and just after, I suspect the valve is not working correctly. Can anyone confirm?
Finally if the CH is on and I turn down the room stat I believe the pump should run for 3 minute but it shuts down straight away. Any ideas on what the fault could be?
Every thing else is working CH / HW comes on and goes off at the right time.
