Yale 6300 alarm problem
10 Jun 2013
Manchester
Hello
Rather frustratingly, one of my family switched the control panel and control panel battery switch off once we had 'learned' the PIRs and attached the siren (switched on) to the external wall.
I assume that the control panel will have 'forgotten' all the PIRs and siren, so I daren't knock it on because I don't to risk the siren going off (which I'm sure it'll do if I take the cover off it to switch it off anyway).
Can someone please advise on the best way to tackle this?
To summarise:
Everything was set up, but the control panel and control panel battery were switched off by mistake. I need to set it up again.
Thanks guys!
Ah, is that even when the control panel battery in switched off as well as the mains power? I was just worried in case the battery was for the internal memory.
yes.
the battery keeps the alarm panel running in the event of a power cut, it lasts about 8 hours.
When worn out, it is possible to fit a Tamiya battery as a replacement, cheaper than the Yale part, provided the size fits inside, but you have to make your own connections.
Thanks, John. It's been over a week since the battery and control panel were switched on so hopefully it hasn't 'forgotten' the PIRs and siren as you advised and I can just switch it on and continue from there. Thanks for your help.
I have known them keep the memory for months, AFAIK it is held permantly.
