Hi just fitted system appears to be working correctly,
I have noted that if in error I leave a door fitted with a DC (burglar) open the control box still allows me to Arm the system ! According to the install manual says :
"If there are faults within the system, i.e. the tamper
switch of a sensor left opened, the user will not be
able to arm the system with the Keypad or Keyfob
until the fault is rectified. The user can use the
control panel to force arm the system by pressing
arm twice and then 3. "
Also if an intruder sets off the alarm and then switches the control box (rear slide switch)
or for that matter trashes the box completely, does the external siren keep sounding
Paul
Paul
