Hi, just moved house, and in the middle of putting up a new alarm, same as I had before Yale 6400, however the control panel light only comes on when you press a button, and goes out after a few seconds or so, unlike my previous system which was exactly the same and stayed on permenantly as it should, to help you see it when disarming in the dark, am I forgetting to Set something or what,
Incidentally when you first set it all up it the instructions say to remove rubber grommet behind panel and throw backup battery position to on, however mine was already set to on, this is a brand new unit, do you think the battery needs to charge up as i thought the light shoul come on when connected to mains.
