I've had this installed for a few months now and assumed it was working since originally it went of when I tested the front door. I've since added a sensor to the back door and also a PIR to the conservatory, did the walk test and they both received the signal. I use a key fob to switch on/off the alarm when coming and going and I hear the beeps etc and responses from the alarm box outside i.e. everything has always appeared to be working ok. However, last night (I had it set to home arm) my wife when downstairs and opened the back door and passing by in full view of the PIR and then outside opening a door sensor on the way but not a sound from any of these. Now I'm worried. I know the front door sensors tick down as soon as I open the front door but the back set up appears to be not working. I've never really tested the back devices by opening the door physically so perhaps I;'ll need to do that to see what happens. Might I be missing something about here? I hear the alarm response signals as we go in and out using the keyfob but all this time the back devices must not have been working. Can anybody advise me how best to approach this problem as I don't think it's the alarm signal so much as the actual devices being recognised.
Thank you in anticipation of any help.
