Having problems testing it, the setup is simple: control unit and 4 PIRs (1 entry + 3 burglar), the layout as below:
PIR1 PIR2
CU PIR3 PIR4
- Pir1(entry) started flashing indicating that batteries need changing.
- Changed the batteries, did a walk test - only pirs 2 & 4 worked.
- Changed batteries in pirs 1 & 3, tested individually (there is a Test button inside). Now doing the test again, - only pirs 1&4 detect movement.
What could it be ?
PIR1 PIR2
CU PIR3 PIR4
What could it be ?
