Yale HSA6200
16 Oct 2014
Merseyside
HI,
Been having issues with my yale alarm for a few weeks now. The problem the alarm tamper.
All i keep getting is the 5 beeps after i set the alarm which means theres a tamper issue, i have checked the PIR (replaced the batteries and relinked), and checked both of the door sensors which also seem to be working fine.
Been up and down the ladder all day now and still cant figure the problem :(
Any one able to help??
Contact Yale, I believe they have support for there products.
Theres only so many places a tamper can come from, if nothing has changed recently to the equipment then the equipment may have gone faulty.
If Yale can't help, then delete the devices off the system, as they are deleted do you still have the tamper fault?
Just had a quick look at the manual and it suggests its the bell box tamper is not fully depressed.
Thanks, all tampers seem ok, just googled around a bit and 5 beeps when arming and de-arming the system means the batterys are low/dead. changed the batteries now, and NO BEEPS :)
hopefully the system is back up and running again now.
