- Joined
- 6 Mar 2009
- Messages
- 201
- Reaction score
- 11
- Country
I’ve just replaced an existing nightlatch with a Yale P89 non-automatic deadlocking one, with new lock barrel, which should deadlock from outside with a reverse turn of the key.
I was expecting the deadlock to require a 360 degree anticlockwise turn to engage (ie the opposite direction to unlocking), but the key will physically not turn through 360 degrees, only 180 - and, obviously, can then only be removed by turning it back clockwise so the lock slot is in its usual vertical position. This doesn’t deadlock the internal latch.
Everything else works as expected - it locks and unlocks (engages the latch at 180 degrees clockwise, fully retracts just under 90 degrees further) fine, and the internal snib deadlocks the internal handle - what am I missing? Could the slot in the latch body into which the tab/tongue of the lock fits somehow be 180 degrees out of turn?
