yale wireless alarm
30 Jun 2013
Hi ive fitted in my new alarm its a yale wirless one which gives you a call when it has been triped the alarmorking ok the problem ive got is i cant seem to get rid of the alarm alarm display what ever buton i press wont turn it of tryed putin code and presing butons alarm works ok thoe can arn and disarfm but cabt get into options thanks
press green unlock then your code and ANY button quickly and repeatedly until it says Alarm Off.
Its in the speed of your pressing that matters or it reverts back to alarm alarm
Thanks 4 the reply tried what u said stil didnt work when i do the code it says system search none then goes bak to alarm alarm any other ideas? Thanks
Take panel from wall and turn around. Using a hairclip or tweezers remove the grey bung and swith the switch you will see in the recess off for five seconds then back on again. replace plug.
Wear earmuffs as taking the panel off the wall will set off the alarm.
I havnt got the back plate on thought this was just for mounting to eall my unit is laying down on table
Better on a wall or your control panel can be accessed without setting off the external siren. The backplate designed to trigger the tamper switch.
one other thought. You dont have one of your buttons trapped in the 'down' position do you? This can make the panel unresponsive.
Do u think the problem might that i havnt got bakplate on as alarm is going of without it on
Seems as thoe backplate is the answer wil try when i get home thanks for the feedbak
