The OFTEC recommendations for buried oil supply pipes are all very straightforward.
http://www.oftec.org/Media/Default/...EC_HomeGuide_DomesticOilSupplyPipes_PUB21.pdf
However there is one point I need some help with:
"Oil feed pipes should be buried at least 300mm clear of other underground services such as water and electricity."
This makes perfect sense when the oil feed pipe is running parallel or almost parallel to another underground service. But what about when an oil feed pipe crosses the path of another underground service, i.e. when the two run perpendicular.
I've got a situation where the oil feed pipe will cross the path of 2 drain pipes, the water supply pipe and the electricity supply. There is no alternative route available to me. Would this be OK?
Thanks,
Nomis
Thanks,
Nomis
