FWL_Engineer said:All other options are pie in the sky and likely to end in tears with expernsive consequencies.
FWL_Engineer said:Andrew, the only realistic way to safely slow a 3 phase motor is with an inverter, these alter the frequency of the supply thus effecting the rotational speed of the rotor.
FWL_Engineer said:Andrew, a basic description of soft stop is a freqency change to slow the motor from full speed to full stop in a controlled manner. This system is often used in process control environments, but there are many applications. The point is that you still need to have an inverter for this system to work effectively, so you might as well install one for standard speed control. The system is also called "Dynamic Braking"
For inverters try this link.
http://www.cse-distributors.co.uk/abbdrives/index.htm[/QUOTE]
thanx for the info...
The brake is activated by a safety device, such as an emergency stop pushbutton or interlock switch and this disengages the AC supply to the motor before injecting the DC current.
Because these units inject in emergency situations only, and not on every stop of the motor, they are not suitable for making machinery PUWER98 compliant.
FWL_Engineer said:Stoday, good link, never came across this system before, but then I have not delat with this type of machinery, however, without knowing the type of use this motor Andrew needs information, this system may not be what he is after
FWL_Engineer said:Shogun, 6.0mm has a 4.0mm Earth core OK..it has done for the last 22 years that I have been in the industry.
FWL_Engineer said:Paul, Service Cutout fuses in Domestic premises and small commercials are BS1361..
