Yorkshire Brass Solder Ring Adapting Male Coupler 22mm x 3/4"
2 Feb 2025
I need to make 3/4" threaded connections to show valve body which I'm planning to use loctite 577 on the thread. As it will be concealed and hidden behind the wall, i dont want to use compression olive fitting after the 3/4" threaded connection. Instead want to just directly go to a soldered joint on copper. is this the sort of fitting that will allow this? i am assuming this particular example below is that type that already has a ring of solder inside ?
