Going to use on pressure washer.If it's a 3/8" X 1/4" brass nipple you're after; most Plumbers' merchants will stock 10x8mm compression coupler. Remove the nuts & olives, hey presto a 3/8x1/4" BSP nipple.......
58p here;
http://www.jtmplumbing.co.uk/pipe-fittings-c433/compression-dzr-fittings-8mm-54mm-c289/jtm-dzr-compression-reducing-coupling-pp9642?utm_source=google&utm_medium=cpc&utm_term=jtm-dzr-compression-reducing-coupling-dzr-10x8mm-size-10x8mm-wras-size-10x8mm-wras-approved-m10100800dzrma&utm_campaign=product+listing+ads&gclid=Cj0KEQjwx7u5BRC1lePz2biJpIYBEiQA-ZeDmi3ifmnKsmOYEF1wCqoIvjAsdY8QJtfJf8qGFwbt9LkaAibu8P8HAQ
58p here;
