Warning: this one is really advanced. I recently replaced one regular dimmer with a new remote-controllable Z-wave enabled dimmer (www.zen-sys.com) and it worked like a charm! I could control the light with a remote or even my computer. However, I then tried to replace a double switch across the room with two new Z-wave switches (one dimmer and one normal relay). Inside the double switch receptacle are 4 black wires (previously connected to toggle switches), 4 white wires previously spliced together and unsed, and 4 copper wires (spliced together unused - previous switches were ungrounded). The Z-wave switches I put in have a black wire (line), a white wire (neutral), a red wire (load), and a green (ground). I hooked black to one black, the red to the other black, the switch's white to two of the receptacle whites, and grounded all greens together. They are set up this way because the switch requires two circuits to be created: one switchable - to turn the light on and off, and one constant - to maintain enough juice to power the radio frequency transmitter (for remote control). The relay switch works fine, but my dimmer does not. To make matters worse, the switch all the way on the other side of the room no longer works. These switches are completely independent and are not set up as a 3-way, yet the improper set up of one seems to be preventing the other from working. I thought it might be bad to have two dimmers on this if there was a chance the dimmers were on the same direct circuit, so I replaced one dimmer with a relay and it still isn't working. Any ideas?
