Zanussi oven
23 Dec 2016
hi I've just replaced the element on my zanussi oven and it's still only getting warm not hot what might it be ?
There are three options:-
1) You fitted it incorrectly
2) You have a bad connection
3) There thermostat is faulty
The last is easy, if the light is going off and on then thermostat, if stays on some other fault.
Thanks for the reply, I've check the fitting twich and I'm now looking for loose connection but all ok, the power light stays on all the time, can a thermostat be fix or is it just replace?
Yeah it's a fan oven and the element is a grill and oven the grill works fine just not the oven, need to get the turkey cooked
Get it apart again and check power to the element wires with a multimeter, if so, duff element,
