Zanussi TD 524 Tumble Dryer not drying properly
8 Nov 2006
London
Hello All
I have a Zanussi TD524 Tumble Dryer that now does not dry clothes properly even after a half load has been set to dry over 90 Minutes. Rcent work done was to grease the Idler pulley for the drive belt and everything was out back exactly as taken apart.
Does have anyone have suggestions as to what maybe wrong and what I should be looking for?
Many Thanks
Have you accidentally pushed in one of the temperature control buttons?
Hi JJ4091
No have checked all settings are the same as before and re-checked again even now. Same results!!
If you are sure it only started after greasing the idler then it would suggest you have managed to disconnect or break a wire going to the base unit or thermostatt. Have another look at wiring & plugs & sockets especially the thermostat
Taken from the manual, Have you checked the filter?
Item 3A is the stat, looks like it is at the back near the pulley you were greasing
