zanussi timeline 1600 replace main drum bearing
5 Aug 2011
Leicestershire
zanussi timeline 1600 replace main drum bearing - do I have to remove the whole inner unit, ie take drum out of the body / door seal etc
18 May 2008
Cornwall
Posting PNC's help us to identify the machine correctly as you have different parts even on the same models depending on when they were made.
Generally you have to strip down a machine to do the bearings as you have to remove the inner drum which requires splitting the outer drum and removal of the door boot.
Depends how bad the bearings are they can be easy or swines to remove. You will need to check the drum support shaft (spider) as well for wear or corrosion.
