Hi there,
Switch the machine on - nothing happens (no power light on the door, no water entering). Leave the machine on and loaded up and the machine starts spontaneously some time later - could be 10 minutes, or up to an hour later. Thereafter runs fine and completes cycle. Inconvenient if you need laundry in a hurry.
Took the lid off to look for loose connections. No obvious problems apart from a build up of debris (calcium?) on the red plastic arm that's moved by changing the program.
Any suggestions about possible source of this problem much appreciated. The machine is circa 10 years old, so possibly not worth calling out an engineer.
Thanks in advance for any help.
