Zanussi Washer dryer
2 Oct 2012
Leicestershire
Hi.
I have the above washer dryer with the modal number ZWD12270W1, just recently when i have been trying to dry my washing it is taking nearly 3 times as long.
When it should be finished the clothes are still hot and steaming.
Any thoughts on this and how to resolve it would be greatly received.
Many thanks
It might be a blockage in the condensing vessel or failure of the electric water valve that provides a trickle of water to the condenser during drying.
Select drain and start the cycle when it starts draining press both the start/pause button and the next button to the left of it at the same time keeping them both held in if E12 appears in the display then you need a new inlet valve as a coil has become open circuit if theres another code post it here (E72 & E73 are dryer NTC faults or wiring to them ) but as previous post says it may also be the condensor has become blocked under the fan back right corner. also worth checking dryer fan and fan belt condition.
