Zanussi washinh machine fle1116w
20 Jan 2008
Leicester
My washing machine does not seem to be heating the water, i have tryed looking for the thermostat so that i can replace it but i am not sure where it is can any help me.
Likely to be the heating element. need to see if it has gone open circuit. Fits into bottom of drum but at front or rear I do not know for this model. A circuit tester is needed with machine unplugged! They can be a b****er to get out.
What makes you think it's not heating?
There are pressure switches and an NTC sensor to control the temperature.
If the pressure switches were at fault the machine should report an E30 fault. If the NTC is at fault then it would report E60.
If you're not getting an error code and the machine is going all the way through the program then it's not detecting a fault.
