Zanussi ZBB27540SA-freezer good but not fridge
26 Jun 2025
Hi
I understand this issue could be evaporator fan related. (No cold air circulating in fridge). Have switched off for 24 hours but no cigar. Does this sound like fan motor knackered? If so, is it fairly accessible on this model? This is integrated, can’t see any obvious removable panels or screws in either fridge or freezer.
Many thanks.
The duct between freezer and fridge often gets blocked with accumulated ice. You can't see it because it is behind the back wall. To melt it all out, you have to empty both parts, and leave the doors open for af least 24 hours. When the ice is melting, you will see it dripping or pooling inside the cabinets, or into the evaporation dish round the back, on top of the motor.
Because the ice is inside the duct, it is protected and takes a long time to melt.
Leave the doors open until the dripping stops.
If you turn it back on before all the ice has melted out, you have wasted your time.
Thanks. Haven’t been monitoring 24/7 but haven’t seen or heard a scintilla of dripping/pooling. How would I see dripping into the “evaporation dish around the back? Looks like I’ll have repeat the last 24 hours.
You'd have to pull it away from the wall. In some cases the motor and the dish are visible, and you can clean it out, in some cases it is concealed behind panelling.
When the machine defrosts itself, or collects condensation from the gutter in the fridge cabinet, the water drains through a small tube into this dish, and the heat from the motor dries it out. It tends to hold a sludge of old kitchen dust, and sometimes food fragments from the fridge, so I like to clean it.
If you have been defrosting it with the doors open, some of the ice should have melted, and the water run out somewhere, unless the ducts are still blocked solid with ice, which can happen. When completely blocked, warm air cannot circulate, nor water run out, so defrosting is very slow.
Thanks again. The problem is access. I guess I need to disconnect unit from cupboard etc.
With luck, once you get it fully clean the self-defrost will prevent it blocking again. If it blocks again within a year, it is probably beyond economic repair.
Excess frosting can be caused by accidentally leaving the door open, or by worn or damaged door seals allowing humid air to enter.
Hi again JohnD
Two further questions if I may:
1. I’ve now completely emptied fridge and freezer, food trays shelves etc for the second stab. Found back panels in the freezer, so tried to remove to assist thawing process, whether they expose the evaporator or otherwise. Unfortunately, unable to remove screw in top section (first two images)as frozen solid after ten years. Will removing that panel and other two below help the thawing process? (I didn’t knacker the flat head on the screw btw)
2. Later, I’m going to remove wooden doors and then the screws connecting appliance to carcass. In relation to this fixture (third image), can I remove fixing screws under plastic cover to decouple unit from carcass without the hinges that connected doors to main body of unit?
Taking the panels off will probably expose the ducts so warm air can get at them. It is common for the "removable" parts to be locked in place by thick ice.
I would expect that you can undo the hinges to take the doors off, but I can't see how.
There is a fair chance you can search for the installation instructions with the model number.
Thanks again. Will let you know how I get on.
The white plastic hinge covers slide out and off revealing the screws to release the hinges.
Hi again
Update on saga:.
Switched off for another 48 hours (fridge and freezer emptied of contents and trays). Also removed panels at back of freezer to reveal fan and element/coil thing. (Fan at top, element underneath) Result-fridge still warm when restarted.
There was one panel, directly underneath fan, which I didn’t remove. Is it likely that this section will expose blocked drain/duct?
Decided not to try and move unit. Have guy coming on Tuesday, but a shame if something simple that I’ve overlooked?
May as well remove it I suppose.
If it has automatic defrost it could be the heater element has failed. But if not and no fault found other than it being iced up then you need to defrost it more often, perhaps twice a year.
Thanks. Yes to automatic defrost and definitely agree with need for more frequent defrosts. So no mileage in exploring under that last panel then?
