I have a gravity fed central heating system with a new condensing boiler that was fitted a few months ago and the whole system was power flushed. Since then the rads have been much hotter (toasty ).
But now the heating sometimes stays on, even though the room stat is satisfied, and/or when the timer dictates the heating should be off.
There's a Drayton Mid Position Accuator MA1.
The heating stays on when it shouldn't maybe once every few two or three weeks, but each time it's when I've had the heating on all day. My impression is that the motor is getting too hot. If I drop the motor unit off the pipes (when the timer and the stat are 'off'), the heating goes off after about 5 - 10 minutes.
A plumber had a look, dropped the motor off, sprayed some WD40 on the copper spindle, and said if it carried on sticking the whole system would need to be drained down and the valve replaced.
It is possible to tell whether it's the motor that needs replacing, or the valve itself?
Thank you, and happy new year!
