Zone Valve??
3 Jan 2006
Durham
I am on installing underfloor heating but can see a problem that im hoping someone can give me a simple answer to.
This is a link tio what i want to do:
http://www.underfloorheatingdiy.co.uk/wiring_boiler.html
Its the bottom diagram. (without a boiler)
Anyway my problem is i dont have a zone valve in my heating system apart from the one supplied with my underfloor heating. If by using the underfloor heating controls to heat the underfloor only (turn on the boiler), the rest of the heating system will heat up as there is nothing to restrict the flow.
Is there anyway i can get round this? I know some one will just reply yes put a zone valve in, but as a DIY man im not upto speed on best way to do this.
Unfortunately the answer is as you suspected. The bottom diagram is self explanatory and clear.
Once the heating system is drained it would be an easy job to cut in the extra 2 zone valves.
The wiring is also fairly straight forward, just follow the standard Honeywell wiring diagram for a 'S' plan system.
More information needed - do you have:
. a combi boiler
. a cylinder
. a room thermostat
If it's a combi then you could just add one zone valve and wire it as an S plan system with the underfloor masquerading as the DHW circuit.
If not a combi then it's similar to S plan but with more than one heating zone.
