Hi All,
Looking for some help and guidance.
I've have this boiler for a number of years, about 5, and all's been fine until recently, when I started to have problems on DHW side of the boiler.
Noticed that I was not getting HW at one of the taps (1st floor about 20ft away from boiler) but put this down to the pipework being a bit resitricted up to a mixer tap but eventually the kitchen tap, being about 6ft away, stopped producing hot water.
Called in my plumber and he advised that the Diverter Valve Assembly was knackered and need replacing. He diagnosed this was the problem as with the hot tap running, the central heating pipes started warming up and I had noticed warm radiators when they shouldn't have been as the CH side was not running at the time.
There was also a small leak from the jointing nut between Heat Exchanger and above the DHW flow valve, although a tweak on the nut sorted this out but it has left an amount of limescale down the outside of the DHW FV and underneath it.
I would use my plumber to sort out the problem but he has become unavailable, and I know finding another one can be rather difficult.
So, is the DVA finished, or is it just part of the assembly or could it just need a service?
Also, are any of the above options really a DIY fix and if so where would the best place be to obtain the necessary parts?
The CH side of the boiler works fine.
Thanks all for your help.
Regards
Jules
Regards
Jules
