M
Millennium_Boy
I still get conflicting information about installing domestic 3kw immersion heaters.
The way I do it is to run it off a 16a breaker, in 2.5mm cable, to a 13a Switched FUSED connection unit, and then with immersion flex to the heater itself.
Some people say that the fuse is a bit overkill, and say just use a double pole switch instead - what is right?
