- Joined
- 5 Aug 2004
- Messages
- 2
- Reaction score
- 0
- Country
Can someone advise.
I have a conventional wall-mounted bolier in a 4 bed detached house. Both house & boiler are 16 years old... The pump in the system is brand new (less than 2 weeks!!) however, when the system is running the pump is VERY hot to the touch. The person who replaced the old one made the comment when they did it that the old one seemed to be running too hot...
This has the effect that after the system has been running for a while it will cut out with a loud 'CLUNK'. Then, when it tries to kick in again it will almost immediately do the same. Again I was told that this was due to the bearings in the pump seizing up because of the heat inside the pump. If you leave the system off and let everything cool down for a while it will work again until it seems to over heat.
My question is what is making the pump too hot. Is it running too fast/too slow? If so, how can you change the speed? Is the thermostat on the hot water tank set too high (incidentally what should it be set to?)...
Or is the boiler just knackered and causing excessive heat??
any assistance/advice would be much appreciated,
thanks
Can someone advise.
thanks
