Neff oven connection B6774
Status
Not open for further replies.
6 Aug 2008
Hello,
I hope someone might be able to help?? I’ve had a good search around and can’t find anything on this:
I recently installed a single neff oven with its own power supply – no problems. I now wish to install a neff combination microwave oven (B6774NOGB) above that, again with its own cooker switch with own power supply.
I bought a second hand oven from a reliable source, and was given the original plug to wire in as it had previously been hard-wired in by neff technicans. On opening up the oven, there is no obvious place to wire in the original plug lead – there are only connection ‘paddles’ – ie no connection terminals, ie screws (as per the oven I just wired in). I’ve attached a pic so you can see what I’ve got to play with.
Is this normal? Do I convert the cable I have to attach to the paddles? I am worried that if the final connection terminals for N,L &E have been removed, then there may be other bits missing, so reluctant to make the connection.
Any advice would be extremely appreciated!
With thanks.
I'm guessing but it may have originally came with the flex attached (My Neff hob did) which was then connected to the cooker outlet plate. When it was removed they have disconnected it at the oven end. (In other words nicked your cable)
Edit - Excellent link below stem.
greenfingers101 - I found a B6774B0GB/01 model listed in their spare parts shop. They have a supply cable part number 496629 available for £3.50
Status
