My house is a semi-detached bungalow, the gable end facing South. Earlier this year I had the walls cavity insulated and I topped up the loft insulation to 250mm. I've just been up in the loft and noticed condensation on the boards above the rafters, but only down near the eaves - the boards at the apex are dry. I don't know if this problem has existed in previous years as I'd never checked before. I think my loft set-up might be slightly different to the norm as the East and West inner walls meet the loft inner roof around 9" above the loft floor and they are sealed along the roofs length. I am hoping that fitting soffit vents at front and back might solve the condensation problem but bearing in mind that the air from the vents will only enter and leave the main loft area at the 4 corners is this likely to provide adequate ventilation in the areas of condensation? I'm trying to get away with the cheapest and easiest option first
