I know this has been discussed before but new products are always coming onto the market and I am sure someone will have found a solution to my project.
I am going to be fitting a solid oak tongue and grove floor; the planks are 160mm wide, 20mm thick and vary in length from 400mm – 2600mm.
The property is a 1960 built bungalow that had thin floor tiles glued down with what looks like Bitumen glue. The tiles were removed in 1999 at which point the floors had a coat of PVA (3 – 1 with water) what’s left on the floor is a very, very thin (as thin as a sheet of paper or thinner) coat of black stuff which I assume is Bitumen glue residue.
I have done a standard damp test by duck taping down a bit of 12” square polythene DPM and leaving it for 24 hours with the carpet back over it, when I removed it there was NO water droplets at all, so I assume there is no damp.
The Bitumen residue is very solid with no flaking and is very thin you can see it was put on with a very fine notched trowel (I would say about a 3mm spacing between notches) the glue left on the floor therefore looks like this, it has a 2mm wide (max) strip of glue and then a 3mm wide strip of the concrete floor showing, this is in wavy patterns all over the floor.
I have tried to remove the Bitumen in a 12” square area I have tried with a belt sander and a wire brush on an angle grinder and a paint scraper but it too solid and thin to get off with the scraper and all that happens with the power tools is as soon as it get hot it just smears over the floor. Therefore removal doesn’t seem an option.
I have been told by the Lecol rep that if the Bitumen is very thin and solid with some concrete showing through (as I have described) that I could apply 2 or 3 coats of “Lecol PU 280” which will act as a sealer/membrane and then use “Lecol MS 250 plus” to glue the floor down.
Please can anyone tell me has anyone used this method? is this likely to work?
Or has anyone found any other sealer/glues that will/have worked over this Bitumen residue
Or what other options do I have?
My thoughts are in this inventive world we now live there must be some products that will enable me to overcome my problems.
Thank you to anyone that can help.
