I'm looking for a bit of advice. I had this boiler fitted last year and straight away noticed it wasn't working right. Hot water is fine. When the heating is on the burner is constantly going on and off. The pump is running constantly while this is happening. This means that the rads never get up to temp so that the room is warm enough to switch off the room stat. To me that's not right. My old boiler would fire up and keep going untill the room stat tripped and burner and pump turned off until heat was called for again.
I did report this to BIASI who sent out a firm. They were useless. First time they told me it wasn't powerfull enough for my house. I only have 5 Rads. Next time they came they drained some water from the system, but didn't top it back up. Then he said it's probably the room stat as it's quite old.
Now I suggested what I thought was wrong both times they came but that was ignored.
Looking for opinions on what you think is wrong with it. Thanks
