I have a Myson Apollo boiler which is approx 14 years old. The problem is that 4 or 5 minutes after the water or heating has turned on the following occurs.
There is an audible click from inside the boiler, the pump then turns off but the boiler still runs. The water then boils as the pump is not pumping which causes lots of bangs etc. in the boiler area. After 5 - 10 seconds of this the boiler trips out and when it restarts (a few second later), everything is OK!
The system then appears to run OK until either the water or heating comes back on with the timer!
Any help would be appreciated as I think it can not be doing the pipework any favours!
