Hi
Appreciate some further advice:
On the top floor I have a hot water cylinder and on a platform above it an asbestos CWST. From this starting point I need to eventually have a nice shower running to keep the wife happy. The bathroom is on the same floor so currently there's no flow if you raise a shower head above waist height.
I've ruled out a combi (see a previous post for details) and moving the cwst into the loft (owing to cost/having to re-inforce joists). Current plan is to fit a negative head twin impeller pump connected to a thermostatic shower.
Issues:
1) I can't drill a hole into the asbestos tank for obvious reasons and as I understand it's advised not to tee off an existing feed (either to the cold taps or cylinder) to avoid dry running the pump.
2) also there's not enough space between the cylinder and cwst right above to fit a Surrey flange and I don't feel confident enough to fit an Essex. Again I understand this is best practice to avoid dry running.
So I see my main option to be to replace the CWST (and probably the cylinder as well to a new, more efficient one as it's not lagged). This also means I can easily fit a flange at the same time.
Any thoughts/advice on this?
Issues:
