Hello,
In trying to save space I've been looking at multi-foil for the ceiling insulation on my loft conversion. Given TLX (thinsulate) and Gen-X have BBA approval I figured it must be ok. I'm trying to work out how deep it will actually go to compare against normal insulation but there are two installation diagrams and I'm not quite certain.
Both have 70mm PUR then 25mm air gap then multi-foil, followed by a 25mm air gap and finally the plasterboard.
However one has the PUR right next to the breather membrane below the tiles and the other has a 50mm gap between the breather and the PUR.
Can anyone tell me which I require, I always thought you needed an airgap, but I figured there must be a reason. If it helps, my current rafters are 100mm. Obviously I'd rather go for the smallest (i.e. no 50mm air gap), but if it's needed then I'll do it.
If it helps, the diagrams are here:
http://www.just-insulation.com/pdfs/multifoil/Thinsulex/Thinsulex_Silver_Install.pdf
(namely options A and C)
Thanks for any help.
