we have an combi baxi 105e instant
The problem is that when you turn the hot water tap on the burner won't fire up and the water comes out cold . Unless we put the hot water tap ON FULLY it will then work and hot water will come out.
It used to work if you just slightly turn the hot tap on.
How do i make it when we open the hot tap half way and hot water come. to make it more sensitive again??
