- Joined
- 22 Feb 2006
- Messages
- 391
- Reaction score
- 27
- Country
Hi guys
Have a 5-year-old Firebird oil burner and pressursised system and it's just started losing pressure. This happened a couple of years back and after doing all the above ground things, I found a leak from a pipe under the (laminate floor) and in the screed. (Yep, it was around Christmas time!) Utter ******* of a job. Obviously, with laminate flooring, it's extremely hard to pin-point leaks. Before it gets to floors up, though, a couple of things. Can AAVs lose pressure without physically losing water and can I tighten up the bleed vents for a couple of days to see if things improve? Also, have a couple of AAVs on towel rails. Can they lose pressure, too? Again, cannot see any leaks.
Did initially find the pressure vessel had lost some pressure (down to 15psi), so re-pressurised and now everything's fine when it's hot and pressure's up, but overnight when it cools, the pressure seems to drop. Pressure vessel seems to be holding pressure so I assume that it is fine. Have just bought but not installed a leak sealer. Are these any good? And, assuming it is a connection under the floor, is this going to continually re-occur until I have a coronary?
Edit to say can't see any drips or owt in overflow.
Thanks for any advice you may be able to offer.
Mike
Mike
