pump speed - no markings ! just a screw slot.How to adjust ?
21 Apr 2005
Hampshire
Hi
On my c/h pump there is a large screw slot on top...
Which way is max and which way is min ? (no markings).
Carl.
The large slotted screw is not the speed control - it allows access to the rotor and enable you to bleed air from the pump.
Speed control is usually a three position rotary switch on the side of the pump body - not all pumps are variable speed.
I'm thinking of adjusting it because....
A plumbing engineer adjusted it to max recently (from min) !
He did this to try and get air out of the c/h system - i sometimes get
loud banging pipes when having hot water on only (after boiler on for 5mins) - but if i turn on the c/h the noise in the pipes stop !
slackjawgaze said:
Hi
Carl.
This sounds like the problem I have, sometimes our house gets cold, what should I do?
Loud banging is telling you theres something wrong with the circulation in hot water only.
Call an engineer that can sort it before the boiler packs up completely
[/img]http://www.prideofmanchester.com/theatres/Palacetheatre/nov28-dodd.jpg
[/img]
thought so  8)
