C/H Pump over tightened screw?
24 Mar 2005
Any help with this one greatfully received. On my c/h h/w pump I stupidly unscrewed the large crome screw on the back end of the pump a little water leaked out, at which point I retightened the screw- now I am concerned I have over tighted it, is this possible??? should it be done as tight as possible or should it be only tightened until the water stops leaking?? What are the effects of over tighting this screw??? Thanks in advance!
Macca1977 said:
Any help with this one greatfully received. On my c/h h/w pump I stupidly unscrewed the large crome screw on the back end of the pump a little water leaked out, at which point I retightened the screw- now I am concerned I have over tighted it, is this possible???!
No.
A tweak tighter then when the water stops
It'll be hard to get it out again.
Sorry for my lack of understanding but what is AFIK ??? Does that mean I can tighten it as much as I like?? Thanks
excellent thank you both for your knowledge, if you can help me with my other post ref the noise and shuddering from the pump and from the boiler after it has be running for 5 mins I would be most greatful! Thanks again
