I've got a built in full size Baumatic dishwasher (cant remember the model but can find out if needed) & I've noticed that the last few uses the bottom dishes arent getting clean - even on a full heavy duty clean.
I then noticed that it appeared that the bottom blade that jets the water up had'nt moved from its original position when i loaded the dish washer.
To prove this theory i opened the door 1/2 way through a cycle & set the lower blade at 90deg to the door & shut the door to let the washer continue. I then waited 5 mins & opened the door again & the blade was in the same position.
It seems that water isnt being pumped into the bottom blade but its ok going into the top one. The blade spins freely & doesnt snag anything.
The washer is only 3 years old & it never has really greasy pots in - i rinse them first.
I've also had the lower blade off & couldnt noice any obstrusions - all pipes seem to be clean & clear.
Any ideas or should i start looking for a new dishwasher!!
Cheers
Berry.
Cheers
Berry.
